iradv c5030 E880-004
  • kstan268
    • Apr 2012
    • 85
    i had this machine at customer place always showing this error code..Off on machine will work again but after a while error code again...i check the service manual is controller fan 2(fm12)i did change the fan but still is not the faulty parts ...any idea guys ..
  • teckat
    • 16083
    Re: iradv c5030 E880-004
    check connections
    swap fan (same) (FM11) to FM12 for testing
    J109 - on Riser PCB=FM12
    • Gr8vel
      I've just had the same problem except sub code is E880 - 0003 any luck.
      • Afivmd78
        • Feb 2021
        • 11
        canon 5030 just remove the back cover of the machine and board cover between the pcb and mfp board there will be a fan assembly having 2 fans remove the fan unit and change it from another machine .or just clean it .it will work definnitly
