3300 print issue
  • repeatcopiers
    • Sep 2008
    • 591
    3300 print issue
    I had 2 old 3300 trade-ins, 1 with print, 1 without. The one without print has a very low meter and a finisher so I am trying to move the print to it so I can donate to someone. I moved the network card, boot rom and hard drive. When I try to print to it, the print log on the copier says it completed but nothing actually prints out. Its been a long time since I messed with this model so I am sure I am missing something. I've attached the user data and configuration print outs if that helps.
  • kuby
    • Oct 2007
    • 1409
    Re: 3300 print issue
    Need to move the hard drive over too or update the firmware on the old one. The one that does not print may not have had the firmware for the network/print installed.
    • guitar9199
      • Sep 2016
      • 1100
      You'll need to flash the firmware with the "N" version. Make sure the boot rom is also an "N" type.
      ....just a suggestion, when you flash it.... "Overwrite All" is the way to go!
      • kuby
        • Oct 2007
        • 1409
        And move the Bootrom over to. Has to be the N version.
        • repeatcopiers
          • Sep 2008
          • 591
          I already moved the N bootrom and hard drive from the copier with print, still says it printed successfully under the print log, but nothing printed.
          • guitar9199
            • Sep 2016
            • 1100
            You're not using the UFR II print driver, are you?
