ImagePress C700 error 000066-001
  • masky
    • Aug 2010
    • 49
    Hello I have this machine that when I turn it on,
    it indicates to me on screen, function not available,
    error Code error E000066-0001
    What I can do? Where does this code come from?
  • JParker
    Technician II
    • Jul 2015
    • 51
    Re: ImagePress C700 error 000066-001
    From the manual:
    066-0001-05 Pre-transfer Charging Wire Shutter HP open error
    Detection Description: The Pre-transfer Charging Wire HP Sensor in the Pre-transfer Charging Assembly detected theopen status although the Pre-transfer Charging Wire Shutter was moved to the close position.
    Remedy [Related parts]- Harnesses from the Registration Patch Driver PCB to the Pre-transfer Charging Wire CleaningMotor
    1. Registration Patch Driver PCB (UN8/J2401) to Relay Connector (27P) (Unit of replacement:CABLE, SIGNAL, RIGHT)
    2. Relay Connector (27P) to Pre-transfer Charging Wire Cleaning Motor (M2/J7148) (Unit ofreplacement: CABLE, PROCESS UNIT)
    - Harnesses from the Registration Patch Driver PCB to the Pre-transfer Charging Wire HP Sensor
    2. Relay Connector (27P) to Relay Connector (7P) (Unit of replacement: CABLE, PROCESS UNIT)
    3. Relay Connector (7P) to Pre-transfer Charging Wire HP Sensor (PS93/J10023) (Unit ofreplacement: PRE-TRANSFER CORONA ASSEMBLY)-
    Pre-transfer Charging Wire Cleaning Motor (M2) (Unit of replacement: CLEANING MOTORUNIT)-
    Pre-transfer Charging Wire HP Sensor (PS93) (Unit of replacement: SHUTTER BLOCK UNIT)-
    Pre-transfer Charging Assembly (Unit of replacement: PRE-TRANSFER CORONA ASSEMBLY)-
    Registration Patch Driver PCB (UN8) (Unit of replacement: REG. PATCH DRIVER PCBASSEMBLY)
    [Points to note at work] When checking the harness/cable or connector, perform the following work.1. Disconnect and then connect the connector to check that there is no bent pin and cable disconnection.2. Visually check that the harness is not caught or open circuit.3. If there is any error, replace the corresponding harness/cable.[Remedy] Check/replace the related parts.
