Canon ir 1022 "Out of toner , change toner'
  • Orion2010
    • Jun 2015
    • 176
    [Error Code] Canon ir 1022 "Out of toner , change toner'
    hello to all, i have problem with canon ir 1022, show out of toner change toner, i replace the toner but is appear again.I replace developer cassette, after 5 days work the problem appear again!!! any idea ?
    thanks
  • guitar9199
    • Sep 2016
    • 1100
    Re: Canon ir 1022 "Out of toner , change toner'
    Have you cleaned the white connector? I know this can cause that.
    There is a spring which sets on a plastic piece in front of the developer assembly, and connects the white wire to the contact on the developer assembly. Make sure the spring did not fall off.
    • LeadSlurpee
      Hi, an iR1024A is giving me similar issues. I gave the white cable a look over and disconnect and a reconnect on both ends, but when I look at the sensor test menu for the toner antenna the voltage difference is still the same regardless of whether the cartridge slot is empty or contains a full cartridge. Well nearly full, the copier has managed to spill some toner out of it while looping trough the initialisation, possibly because it thinks it's empty.
      Could a large ammount of toner spilled around the deveoper assembly cause the antenna to give faulty readings?
