Canon IR 3235 disable copies
Re: Canon IR 3235 disable copies
Equitrac= intelligent print management and cost recovery solutions
https://www.usa.canon.com/internet/portal/us/home/products/details/software/output-management/equitrac-174-cost-recovery-solutions**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
You need to set department id to the machine admin/password then from your computer only have to do is uninstall then install the driver to recognize the new setting from copier then try for sample printing if the copier ask for log in to print after done it you can disable it to your copier if you want it.....for your computer it is permanent unless you uninstall it again......good luck....Comment
[QUOTE][/wants is for a user to log in to the machine and ask for a pin whenever theyh want to copy a document a QUOTE]
believe_poster wants it both ways>(log in) desktop printing and walk up (log in) copying.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
That works fine for prints and also to have the machine locked with an admin password so nobody can use it for either scans or copies, but they want a user and pass for every person in the office.
Also, i dont think i can configure any of those options via webmanager, it has to be on the machine itself which is a pain in the ass otherwise ill just do it remotely, this model has made me suffer in every way.Comment
Yes i just found that option, i was looking in the adress book settings just like it is on Ricoh machines, ill try that this afternoon, im wondering if theres a way of having both counters, print and copy, add to the same user or if they are separate.
