IRAC5035 Magenta Mis Match/Skew
  • tt88jm
    • May 2017
    • 3
    Hi All,
    Firstly I would like to thank you all as I use this website a fair bit if I run into problems whilst out in the field. I have decided to become a full member and will also try to help anyone else out when I can.
    I have a iRAC5035 which I have the attached problem with (skew/white line on PG10 test which is causing issues when printing colour docs)
    The following has been done on the machine:
    Lasers swapped so not laser
    New Transfer Ass'y
    New Patch Sensors
    New Magenta Dev
    New Drums
    Checked/Swapped Dev/Drums Drives
    I have also noticed that the mis-match isn't working and fails.
    Thanks in advance.
    Jay
  • mramlawi
    • Jul 2011
    • 838
    Re: IRAC5035 Magenta Mis Match/Skew
    Try to edit the value written on the front door ,make it as default ,you can also try to make clear Dc then turn the values back from the front door.
    Distinguished road makes you jewel in rough
    • tt88jm
      • May 2017
      • 3
      Thanks, I have tried to match the front door values. Also DC and then match values again along with Auto-Grad. No Joy!
      • lilleputte
        • Jan 2013
        • 153
        MISC-P -> AT-IMG-X
        Which firmware version are you using ?
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Patch Sensor shutter is ok?
          Use case When replacing the Laser Scanner Unit to identify the failure position
          LD-ADJ-M level2
          • guitar9199
            • Sep 2016
            • 1100
            Clean the patch sensor, and run "Auto Correct Color Mismatch", do a FULL gradation, and then check PG-10 and see if Magenta is still skewed.
            • zoraldinho
              • Mar 2008
              • 5015
              He wrote "new patch sensors and mis-match fails"
              P.S. Gradation have nothing to do with skewing.
