Ir3245
  • ARUN MISHRA
    • 80
    [Misc] Ir3245
    Machine dispay ,set the finisher as far asit will go,and close the front cover.
    What i do?
    sigpicARUN KUMAR MISHRA
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Re: Ir3245
    I have never seen such a message.Internal or external finisher? Any jam code?
    • bineeshgeorge
      • Jul 2009
      • 107
      Re: Ir3245
      Check accessories power supply board
      Sent from my X41 Plus using Tapatalk
      • guitar9199
        • Sep 2016
        • 1099
        Re: Ir3245
        Push the finisher to the right back into the machine until it latches, and close the front door?
        • teckat
          • 16083
          Re: Ir3245
          What i do?
          FINISHER S1
          The message " Set the Finisher as Far as it will go and close the Front Cover" is on the Display on the Control Panel
          Problem :
          The message " Set the Finisher as Far as it will go and close the Front Cover" is on the Display on the Control Panel. The Finisher is not available to use.
          Solution :
          This can be caused by a faulty Finisher Controller. Check that the Finisher Controller has 24volts present at J1 pin 3.
          If the 24 volts is present check to see if you have 24volts at J14 pin 1.
          Make sure that you have the actuator pushed in while checking the voltage.
          If you have 24 volts coming into the Finisher Controller but no 24 volts at the switch, it could be a faulty Finisher Controller.
          • ARUN MISHRA
            • 80
            Re: Ir3245
            Thanks for responding.
            Thanks for your sagession especially thank Teckat for give me a best solution.
            Finally finisher controller is faulty.
            • teckat
              • 16083
              Re: Ir3245
