Imagepress C1 - black toner problem
  • renemeldgaard
    • May 2017
    • 6
    Hi all,
    My printer just started to make prints like this: 2100_001.pdf.
    There is a line where it does not print on.
    I have tried to clean supply mouth, sensors, paper dust, calibration, ect.
    Dont know what the problem can be anymore?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5014
    Re: Imagepress C1 - black toner problem
    Hi!
    We need to know what is paper format or paper path.Please post a pic of PG-10 test shit. Thanks.
    • renemeldgaard
      • May 2017
      • 6
      Originally posted by zoraldinho
      Hi!
      Here is PG-10 test 2101_001.pdf
      • zoraldinho
        • Mar 2008
        • 5014
        Visually inspect black developer.Before that you can try:
        1.FUNCTION>SUPPLY-H-K
        2.FUNCTION>STIR>K
        If that won't help in service mode check toner supply motor and visually inspect hooper.Also can be bad bk developer.
        • renemeldgaard
          • May 2017
          • 6
          2.FUNCTION>STIR>K
          I am quite new to the Imagepress C1. I have inspected hooper and it seems fine.
          Where is the toner supply motor and the black developer? I cant find it in the service manual.
          EDIT: The foam seals on the black toner drum was gone, maby it can be stock somewere?
          • zoraldinho
            • Mar 2008
            • 5014
            C1 have only 1 drum.Did you try with??:
            2.FUNCTION>STIR>K
            • renemeldgaard
              • May 2017
              • 6
              2.FUNCTION>STIR>K
              Yes I did, its the same as before.
              • zoraldinho
                • Mar 2008
                • 5014
                What do you mean with "black toner drum"?
                Developers are on the carusel.
                Visually inspect black developer! Is it cylinder fully coated with developer powder?Problem is definetelly in bk developer!
                • renemeldgaard
                  • May 2017
                  • 6
                  The foam is missing from the black (not my printer, found this picture)
                  • zoraldinho
                    • Mar 2008
                    • 5014
                    Definetelly it's not in the hooper because it's bigger then hole.Don't worry about the sponge.
                    • renemeldgaard
                      • May 2017
                      • 6
                      Did you inspect black developer? Is it fully coated with developer powder?Problem is definetelly in bk developer!
                      Yes I did and it is coated with powder.
                      Do you have a guide to take it out and clean it?
                      PS. I really appreciate your help
                      • zoraldinho
                        • Mar 2008
                        • 5014
                        Remove the developing assembly cover
