Copier is making a black background intermittently. I have replaced the drum unit and it seemed like that took care of it. Anyone had this problem with this model?
Yes. Drum the cause. Replacing should resolve the issue, also maybe clean the exterior of the laser unit aswell (be careful when removing cables and unit as it can be easily damaged.)
The problem is not the black drum, the problem could be the metal spring that is front of the machine, this metal spring has to be in contact with the drum on the metal part, on the right side of the drum board.....
