sensor double sheet
  • dracon
    • Apr 2016
    • 16
    [Jamming] sensor double sheet
    Hello everyone.
    I have an image-press c850 with a paper deck c1 with double sheet sensor.
    My problem is that the labels generate me codes 2828 (double sheet).
    I have tested with different profiles like Lab-051 and Lab-241.
    Can the sensor be canceled?
    Thank .
    regarts
  • teckat
    • 16083
    Re: sensor double sheet
    imagePRESS C60 / C700 / C800 / C65 / C750 / C850
    Multi-Drawer Paper Deck-C1 / B1
    2828 Jam Code
    Make sure the optional Double Feed Sensor is seated correctly on the attachment bracket / if not it will cause the sensors S009 and S010 to not line up correctly.
    Try Re-seating the sensors to correct the problem.
    • allan
      RTFM!!
      • 5459
      What kind of label paper? Is there gaps between the labels?
      Not my brand but some of the production machines i work on you can switch the function off if its troublesome.
      These ultra-sonic sensors are very sensitive.
      Whatever
      • dracon
        • Apr 2016
        • 16
        thanks to all.
        I will try to see the position of the sensor but I think the problem is that the sensor detects air between layers of the labels.
        a greeting
