Cannot print long sheet on ip c750
+ More Options
Posts
  • V-P
    • Apr 2011
    • 679
    Hi Fellas,
    I activated the long sheet option on a imagepress c750 but when I try to print 70 cm x 30 cm - I get error from Workstation.
    I don't know what is "offending" the system...
    I can make COPY though.
    I have stack bypass option + staple finisher as a standard. Do I need some other accessory ?
    Thnx....
  • khattab.al.masry
    • 212
    Re: Cannot print long sheet on ip c750
    Originally posted by V-P
    Hi Fellas,
    Thnx....
    Long sheet not printed with staple finisher installed
    Remove stable finisher and tray to print
    Sent from my SM-J700H using Tapatalk
    • V-P
      • Apr 2011
      • 679
      old thread but it was a resolution issue
      • onlyinnewfoundland
        • Apr 2013
        • 235
        Yeah - ran into this a few weeks ago actually.
        Canon say for now it has to run 600DPI, fiery will auto-cancel it at 1200DPI which happened to be the standard output for this machine in the driver.
