Error Code 000998-0002-05 on Canon ImagePress 7000VP
  • Lindac
    • Aug 2025
    [Error Code] Error Code 000998-0002-05 on Canon ImagePress 7000VP
    Please help...Machine recently moved to another location. Trying to start up but keep getting the error code 000998-0002-05 on initial start up. Can some please tell me what this error is pointing to and how I would go about correcting the problem.
  • guitar9199
    • Sep 2016
    • 1100
    Re: Error Code 000998-0002-05 on Canon ImagePress 7000VP
    E998 codes after a machine being moved points to loose connectors. Unplug and reseat your connectors on DCON and the Driver PCB's. That should take care of it.
    • Lindac
      I am a new to this machine - I checked the connections on the back of the main controller, where else should I look? If you could describe the area as I have a learning curve to get over.
      • charm5496
        • 2387
        Problem :
        E998 error codes displayed after a new install is performed on the imagePRESS C7000VP Series.
        Solution :
        It has been noted that certain connectors are loose and not plugged in all the way. Below is an example of connectors that have been most vulnerable.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          This is error related to registration feed driver PCB.
          • venluckey
            • 36
            Originally posted by charm5496
            Problem :
            Solution :
            [ATTACH=CONFIG]37113[/ATTACH]
            Life saver, the picture is always worth a thousand words. Working on a C6011, and totally over looked this. First time ever touching this machine.
