IRC2550-"Default key is corrupted or invalid" message
  • Desert Rat
    • May 2008
    • 1089
    I have seen this before, I'm not sure what it means. It was a while age when I saw this message. I think it went away when
    it was installed on the office network. I'm not a network tech, so I know I am at a disadvantage.
    I have not found anything in the book about this message. The machine works fine.
    Can anyone shed some light on this for me?
    DR
  • Tonersniffer
    • Nov 2012
    • 74
    Re: IRC2550-"Default key is corrupted or invalid" message
    You will find your answer here
    • Desert Rat
      • May 2008
      • 1089
      Thanks tonersniffer,
      I did have to put an HDD in this machine. I took it from another model C2550. I do have the certificate for this unit.
      Can this customer use the old certificate?
      Thanks again
      DR
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        No
