Copying using ADF a4 size and detect a3 size scanning
  • rudysemira
    • Oct 2016
    • 108
    hi everyone i have a problem for canon ir7105 when i am copying a4 size the scanning lamp going to right side i used to clean s7 sensor but no luck same problem ..........any solution for this....thanks in advance...
  • ldharnden
    • Apr 2011
    • 47
    Re: Copying using ADF a4 size and detect a3 size scanning
    Have you checked in service mode what the sensors are saying, have you verified that I/O mode shows them working? Have you also checked to see what the RCON is reporting for size while moving the width guide? There is also a width adjustment that you can run to calibrate the tray. It's chapter 17.5.2.1 in the service manual. If all else fails. I do an RCON clear and reset all to the door values for the scanner and reader. Just remember to run your white lvl adjustments and CCD adjustments after. Good luck!
    • rudysemira
      • Oct 2016
      • 108
      thanks for your reply i saw one of posted here in forum about sensor test for adf (reader controller ) i follow the instruction how to do it if there is faulty sensor after test i tried again to copy test now is working fine.......Big thanks......
