canon ir 2525
  • Tamyiapsoon
    • Dec 2010
    • 80
    canon ir 2525
    error code E000520 need help , appreaciate .
  • teckat
    • 16083
    Re: canon ir 2525
    How to clear E000
    Enter service mode by pressing additional functions than 2 than 8 and then Additional Functions.
    #SSSW will be displayed.
    Use the right arrow and scroll to #CLEAR then press OK.
    Use the right arrow and scroll to ENGINE then press OK.
    ERRCLR will be displayed then press OK.
    Then power cycle the machine.
    are u sure about that e000520 ????
    never seen than -520
    Detail Code on this model
    • ARUN MISHRA
      • 80
      Re: canon ir 2525
      I think this is shorter, finisher, unit problem.
      If machine have a finisher unit , than try you disconnected from machine and try a check.
      sigpicARUN KUMAR MISHRA
      • DDlan
        • Mar 2017
        • 26
        Re: canon ir 2525
        Originally posted by teckat
        How to clear E000
        Hi, Teckat.
        Canon Ir 2520 - on sreen show now : Network download available ip address. Machine does not use , all keys do not use too. It may be hung , what's machine and action. I don't understand this machine, please help me . Thank you very much.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5000
          Re: canon ir 2525
          Upgrade firmware.Call Canon.
          • teckat
            • 16083
            Re: canon ir 2525
            Check the DIMM Assembly on the Main Controller ---remove and re-seat it.
            May also be bad------------------------
            Copier display is locked up with a message of '
            Network Download Available' at power on.'
            The message occurred after the Main Controller was replaced.
            After comparing the original Main Controller and the replacement Main Controller, it was noticed that the position of the dip switches on the dip switch bank were in different positions.
            Setting the dip switches on the replacement Main Controller to the following resolved the network download available message at power on.
            Set dip switches 1, 2 and 3 on and bit 4 "off"
            • DDlan
              • Mar 2017
              • 26
              Re: canon ir 2525
              [ATTACH=CONFIG]37247[/ATTACH]
              [ATTACH=CONFIG]37246[/ATTACH]
              Thank you very much. Have a good day.
              • Kings
                Steve@Kings
                • Nov 2009
                • 79
                Re: canon ir 2525
                This is what the manual says.
                Hope it helps
                E520 0001
                Title Shift Motor (M4) error
                Description The shift roller does not leave the shift roller home position
                when the Shift Motor (M4) has been driven for 1.2 seconds.
                Remedy 1.Replace the Shift Roller HP Sensor (S2).
                2.Replace the Shift Motor (M4).
                3.Replace the Finisher Controller PCB (PCB1)
