E000110-0001 Canon iR3045
  • emi kusrini
    • Jul 2017
    • 5
    [Error Code] E000110-0001 Canon iR3045
    This morning, I meet a problem my copier machine iR3045 with error code E000110-0001.
    Please help me what i should do?
    Ty
  • Cabo
    • Aug 2012
    • 41
    Re: E000110-0001 Canon iR3045
    Check Laser unit and DC Controller.Check Fuse on the DC Controller
    • emi kusrini
      • Jul 2017
      • 5
      Thank you for reply,
      I have checked the Fuses on DC Controller with result:
      Fuse 1 = 0,05 (buzzer)
      Fuse 2 = 0,03 (buzzer)
      Fuse 3 = 1,666 ( no buzzer)
      What is the third conclusion of that measurement result?
      • teckat
        • 16083
        Remember that u can't check a fuse that is in series on a board.
        If in series, u can get a false read as good or bad, especially if another component is good or bad.
        How to test a fuse in a circuit.
        Testing the Fuse😱
        Turn the device off first and Remove power.
        Remove the fuse from the vehicle or device.
        Make sure it is turned off before the fuse is removed.😱
        Turn the meter on and set it.
        You can rotate the selector to Ω, or OHMS. ...
        Put one lead on each end of the fuse and look at the display. ...
        Test the fuse.
        By using an Ohmeter to check continuity of componets still in a circuit, you may also be checking other (non-fuse)componets in the circuit as well, thus giving misleaading indications.
        Using a low Ohms setting on the meter might help eliminate (somewhat) this problem.
        • emi kusrini
          • Jul 2017
          • 5
          Testing the Fuse😱
          Test the fuse.
          I have remove the fuse from dc controller PCB. And have tested with result : Both of three fuse in good measurement. 1 fuse was failed.
          Now I confused how much ampere or how wattage these fused.
          I dont have schmematic diagram for this DC Controller.
          Please help me.
          I
          • teckat
            • 16083
            Did u note where u removed it from on pcb ?
            Post a pic of fuse.
            • Cabo
              • Aug 2012
              • 41
              Post a pic of fuse.
              I think the value F3 is 0,5A (I'm not sure)
              • emi kusrini
                • Jul 2017
                • 5
                Post a pic of fuse.
                This's pict my fuses
                Thank you for reply
                • Brian8506
                  • 1665
                  When the side door is closed, the laser shutter is opened via a cable that goes from the interlock area around to the laser where it opens it from underneath. I have seen this cable broken. Or you may simply have a bad laser unit.Found this also
                  Error :
                  Error code E100/110
                  Workaround :
                  After replacing the laser, laser motor, main controller, dc controller, and checking the wiring the problem was resolved by replacing the registration sensor.
                  Problem :
                  Error and jam codes are very intermittent. J0201 happens with no paper in path, history showed E100-0001 & E110-0000. Replaced Laser Assembly and PS10 then tried a DCON clear with no change in codes.
                  Solution :
                  Replacing DC Controller { FM3-1262-000 for 3025 & 3030 }{ FM3-1263-000 for 3035 & 3045 } resolved issue
                  Error :
                  E100, E110 Error Codes
                  Workaround :
                  Although the Main Power Supply, Controller Power Supply, DC Controller, Laser, and Drum, were replaced for this issue, the Accessories Power Supply Pcb. resolved the problem (Part number FK2-0338-000).
                  • teckat
                    • 16083
                    [ATTACH=CONFIG]37302[/ATTACH]
                    [ATTACH=CONFIG]37303[/ATTACH]
                    Thank you for reply
                    believe that is a PICO Fuse _ Littefuse _ Fast Acting
                    it has radial leads === angled down
                    epoxy solid color coated ? usually 125v - L F 5 is most likely Amp rating ?
                    bring to electronic shop
                    • charles
                      • Jul 2017
                      • 8
                      Ty
                      The scanner motor is faulty.
                      The scanner motor speed lock signal does not indicate a locked state a specific period of time after the scanner motor has been started
                      open the top and check the scan is moving
                      • emi kusrini
                        • Jul 2017
                        • 5
                        Are you sure these fuse is 5 Ampere?
                        • teckat
                          • 16083
                          Not sure, u will need to bring it to a electronic shop.
                          Looking for a wiring diagram, get back , if I can locate
