Image Faults CANON IPR1110
  • rodrigo neres
    • Feb 2012
    • 25
    Dear SirsI'm
    having this defect on a Canon IPR 1110
    and I can not heal.Corona, belt, cylinder, roll of the developer box replaced.
    I appreciate any tips
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: Image Faults CANON IPR1110
    Can be many thing like bad ground,drum cleaning blade,laser unit,controller,bad gear......
    do you have repeats on large format like A3? rendom or Pattern? Samples have horisontal stripes i believe.
    • rodrigo neres
      • Feb 2012
      • 25
      Because it is, as I write in the message, the defect appears horizontally in both A4 and A3 format Grounding, are ok; Machine has 2 million impressions; Cylinder, blade, belt are optimal;
      • onlyinnewfoundland
        • Apr 2013
        • 235
        Looks like it's always the same distance apart?
        Maybe secondary transfer is being weird?
        • rodrigo neres
          • Feb 2012
          • 25
          Was what I thought at first, but I changed both and the error continues
          FM3-2806 and FM3-2807
          New parts
          thank you anyway
          • charles
            • Jul 2017
            • 8
            [QUOTE=rodrigo neres;572521]Dear SirsI'm
            IMG-20170720-WA0016.jpg[/QIMG-20170719-WA0012.jpgUOTE]#
            pls 1. check the pre-transfer corona wire 2. the transfer belt
