Adv 4045 Add Toner
  • repeatcopiers
    • Sep 2008
    • 591
    Adv 4045 Add Toner
    Customer has Adv4045 with 140k copies on it, they say for about a month the copier has been asking them to replace toner cartridge but the cartridge is not empty. They actually threw away 2 cartridges even though they felt full???? I remember having this on one of the older ir3245 units and had to replace the entire hopper assembly.....is that what I'm looking at here? Is this common on this model?
  • shawncrowther
    • Sep 2013
    • 19
    Re: Adv 4045 Add Toner
    Developing Unit Gear comes off and causes a similar issue
    Remove Developer Unit
    Check gear is on it and not fallen into chassis
    • dan7777
      • Dec 2012
      • 680
      There was a problem with a gear in the hopper. A new hopper should have the new style gear.
      • doktor
        • 212
        That was fault on my machine.Good luck.F1-T01-N14-10037-02.pdf
        • racional
          • Nov 2017
          • 2
          FC9-0612 GEAR, WORM
          FU8-0514 GEAR, 43T/18T
          Replace both if they are damaged , in a hopper or subhopper motor assembly, must look
          • blackdog
            • Jun 2012
            • 211
            Hey thanks to all for the solution.
            Toner Hopper...
