IR3225 Send
  • Brian8506
    • 1665
    IR3225 Send
    Only on send to folder or email adf will feed docs then say to change original and press start again almost like a job build feature. I'm thinking there's a setting but haven't found it. Otherwise all you have to do is press done and it send to the folder. Any ideas? It works so it's not the end of the world.
  • teckat
    • 16083
    Re: IR3225 Send
    "Change Original and Press the Start Key", that message is a Pain in the Butt. -----seen various causes on all iR's models
    Do u receive message on copies/scans off glass (not using ADF ) ???
    Change Original and Press the Start Key" Message Is Displayed, After Scanning One Original From The Glass
    on some color iR's ---------
    u needed to
    --Make sure Different Size Originals is not "ON" under Special Features mode.
    --Initialized in user mode---the
    Common and Copy Settings.
    • Brian8506
      • 1665
      Re: IR3225 Send
      Not copies. Didn't try send off glass. Copies are ok off glass or adf. Scans thru adf give message.
      • teckat
        • 16083
        Re: IR3225 Send
        Make sure Job Build is turned off under Special Features ---if on ( see pic ) customer receives the prompt to change original
        this was the case on iRC's models
