Ir 3045 jam and other wise white copy and err 733-0001 coming
Sent from my SM-G7202 using Tapatalk
when does code pop ????
code indicates a communication error with the printer at startup
check/ replace flash dimm on the dc controller Try an Error Clear in Service Mode and power cycle the machine. Check the ribbon cable between J301 on the DC Controller and J1029 on the Main Controller. Make sure that this ribbon cable is seated properly.
Make sure that the DC Controller has proper regulated voltage at J320 and J319. At J320 the voltages should be (pin1) 13VDC, (pin2) 5VDC, (pin5) 3VDC, and (pins 3 and 4) are 0VDC. At J319 the voltages should be, (pin 1 and 3) 24VDC, and (pin 2 and 4) ) 0VDC.
