picked up a new IRA-C5051 pc test 10 colers not lining up on edge to edge color blurr
  • wachman
    • Apr 2014
    • 50
    have only 2 others of these and haven't seen this issue with the others. new copier account i picked up has a Ira-C5051 PC test bars not lining up correctly causing blurry color print. is there a laser adjustment I am missing?
    normal gradation adjust is not fixing this issue.
    Any help is appreciated
  • madas
    • Aug 2008
    • 313
    Re: picked up a new IRA-C5051 pc test 10 colers not lining up on edge to edge color b
    Got a sample of the test page?
    i have had where the bars are up n down to each other or high on say cyan and magenta ok that sort of thing.
    I did a dc con reset and did the trick!
    just my experience and there could be other than that but it worked for me?
    good luck and if you do someting else and it works please post your fix.
    Madas
    • wachman
      • Apr 2014
      • 50
      Ok so on further inspection it looks like it is just the magenta bars will be trying new drum to see if that works
      • Northwestservice
        • Jan 2011
        • 140
        any time you remove the transfer belt assy go into service mode, func., misc. p., AT-img-X and okay, go check your pg-10 and the colors will be aligned
        • wachman
          • Apr 2014
          • 50
          Thanks Northwestservice!!! that was it!!!
          this is why I contribute to this great site!
