Canon ImageRunner C5235 jams after removing fuser unit
  • DMP
    • Aug 2017
    • 26
    [Jamming] Canon ImageRunner C5235 jams after removing fuser unit
    Hey Guys,
    We have a Canon IR C5235 copier machine which we use daily to print manuals.
    Today one of the guys accidentally left a piece of plastic in between the paper stack which rolled on the fuser fixing film. I took the fuser unit apart and removed the piece of plastic, then put it back together and installed it back on the machine. Now every time I try to print, the paper jams by hitting a small screw right under, middle of the fuser unit. Looks like paper does not get properly guided into to the fuser unit.
    I would really appreciate if you guys could give me a hint or advise on the issue. Not sure if I am able to attach images since this is my first post. I will try to upload a photo pointing the small screw where paper hits it.
    Thanks in advance!
  • DMP
    • Aug 2017
    • 26
    Re: Canon ImageRunner C5235 jams after removing fuser unit
    • Burdy500
      • May 2016
      • 44
      Originally posted by DMP
      what's the jamcode?
      with kind regards
      Copyfan
      • DMP
        • Aug 2017
        • 26
        Originally posted by Burdy500
        what's the jamcode?
        with kind regards
        Copyfan
        Hey Burdy500,
        I will need to enter service mode I guess to see the jamcode. Not sure how to enter service mode on my copier.
        • roho
          • Mar 2009
          • 844
          I believe there is a black plastic guide that is fastened with that screw. Check to see if the guide is sitting properly. It has slots to keep it flush, then is screwed in to keep it stable. It almost looks like that guide is missing in your pic, can't exactly tell.
          • roho
            • Mar 2009
            • 844
            You would be best served having a technician in to look at this.
            • Burdy500
              • May 2016
              • 44
              when the screw does nothing you could get it away....
              • DMP
                • Aug 2017
                • 26
                Thanks Roho for your reply.
                I am trying to avoid dealing with Canon Corporate as I have had very bad experience with them so far. This would be my last resort. If you guys know a reputable independent technician or local company in Palm Beach, FL area I would be glad to call in a service.
                Would it be possible the plastic wrap piece which got dragged into the fuser may have ripped that plastic guard and transfer belt moved it inside the copier? It is a pretty wild guess. I don't see any plastic levers or anything to lift the transfer belt up. It looks like paper does not get rolled onto the transfer belt way before going into the fuser. There are total of 3 screws aligned to that same metal bracket.
                Again I have only touched the fuser unit. I pulled it out and back in 10+ times with the hope I could notice something.
                Thanks again.
                Bellow couple more zoomed out pics.
                • dan7777
                  • Dec 2012
                  • 680
                  Hey Guys,
                  Thanks in advance!
                  Item 9 needs to be on fixing film unit. If it is not it will jam.
                  • roho
                    • Mar 2009
                    • 844
                    I now have been able to check your pic against a machine. The paper never travels along the ITB. It travels up the side of the machine from the cassette and into the fuser. You must have done something to the fuser as it is not allowing the paper to feed into it and is curling it to that screw on the frame. The fuser has a black plastic inlet guide, make sure this is properly mounted. You will need to remove the fuser again, check if everything is fit together right. What did you take apart on that fuser? Check those areas carefully.
                    • DMP
                      • Aug 2017
                      • 26
                      [ATTACH=CONFIG]37492[/ATTACH]
                      Hi Dan7777,
                      Thanks for your reply. Can you send a link of a better quality image. I cant really see #9 on this one. Probably pic size reduces when it uploaded. Thanks
                      • DMP
                        • Aug 2017
                        • 26
                        Hi Roho,
                        Thanks again. I will take the fuser off again and inspect it again. The only issue with the fuser was it had that piece of plastic wrapped around the fixing film.
                        • DMP
                          • Aug 2017
                          • 26
                          The error code is 0106 consistently since yesterday when the problem happened.
                          I have scheduled a local technician for early morning as it looks finding the issue is beyond my capabilities.
                          Thanks you all again for trying to help me here.
                          • mender
                            • Aug 2012
                            • 16
                            These pics may help. If you have the unit out make sure the fuser film is rotating when you turn the gears.
                            • DMP
                              • Aug 2017
                              • 26
                              Thank you all again for trying to help. Issue was solved. Simple problem. A sensor pin was stuck, pushing the paper into that small screw.
                              I would like to give a shout out to Nick with ItemInc who spent almost an hour on the phone, trying to help me out. Also my new local service provider John with PC & Printer Paradise, based in Boca Raton who located the problem right away. If I would have had to call Canon Corporate it would have costed me several hundreds and probably a bunch of unnecessary replaced parts. I might share my horror story with Canon Corporate in another thread when I purchased the copier.
                              Thanks again!
