Is possible to access machine on different network?
  • oxzz
    • Sep 2017
    • 39
    [Misc] Is possible to access machine on different network?
    hello, i just wondering about accessing IR or IR ADV device can be access using different network?
    if this way is possible, what port i need to open or setting on machine for each application below:
    1. Imageware Enterprise Management Console ( )
    2. Imageware Management Console ( )
    3. Remote Operation Viewer ( )
    4. RUI (enable RUI, open port 8000, this work perfectly )
    i have try to add device in IWEMC from different network, but i got nothing to connect the device.
    maybe you can show me the setting on machine for this prob?
    im not a canon dealer, just have 3 machine for rent.
    regards,
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Is possible to access machine on different network?
    If you opened up and forward the relevant ports on a router / managed switch / firewall you could directly communicate with a machine over the internet, but I wouldn't recommend it.
    Probably the best and more secure way is to arrange an RDP or Teamviewer login to a pre-configured VM running on a server that has the exact apps, network and share level access required.
