Tab Attachment Kit-F1
  • Ingersoll
    • Nov 2008
    • 74
    [Jamming] Tab Attachment Kit-F1
    I installed a Tab Attachment Kit-F1 on a Canon iR-Adv 5535i [which came with 0 instructions] and can't get the PC and the copier to agree on printing. If you set the paper in the tray to Tabbed Paper w/ 5 tabs then the PC can't select that type of paper. Any ideas? Has anyone used this kit before and had it working? What type of tab paper is best?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    Re: Tab Attachment Kit-F1
    I used it once. Only worked from a certain cassette.2, if I remember
    • Ingersoll
      • Nov 2008
      • 74
      Yes, but no instructions in the box, no instructions in the Service Manual or Service Guide AND it can be done from the bypass tray on the new iR-A 5500i series, so technically you don't even need the adapter. I still did not find a way to make it work.
      Knowledge is NOT power if it is not used, Applied knowledge can be power.
