C5305 ImageRunner Advanced Scanner/Copier Feeder
  • LynnOnTheWeb
    • Aug 2025
    Hi All,
    Is the feeder for the scanner/copier autofeeder adjustable? If so, can you point me in the direction of instructions or a how-to? I haven't been able to find anything in the manuals.
    I have a lot of jams/misfeeds (where multiple sheets go through at a time) to the point that it's almost unsuable. I I also have a Konica Minolta I have in the office, and these issues are rare with it.
    Thanks!
    Lynn
  • JPiek
    • Oct 2014
    • 435
    Re: C5305 ImageRunner Advanced Scanner/Copier Feeder
    Try cleaning the rollers and separationpad, if that fails replace them.
    Johan
    • teckat
      • 16083
      Originally posted by LynnOnTheWeb
      Hi All,
      Thanks!
      Lynn
      Color Image Reader Unit-B1------Pickup Roller Unit (Pickup roller, Separation roller) + Separation Pad---on both > Clean 40,000 sheets / Replace 80,000 sheets
      or
      Duplex Color Image Reader - B1------Pickup Roller / Feed Roller 1 Unit + Separation Roller -------------Replace all at 80,000
      as stated-----------u need to inspect & clean
      • petermays
        • Mar 2017
        • 91
        hi..if multiple pages are picked up then its the separation pad.replace and check the feed roller and pick up
