a 'quick' firmware naming question
+ More Options
Posts
  • JPiek
    • Oct 2014
    • 435
    [Misc] a 'quick' firmware naming question
    I was at a customer having a IRc2020... After changing the ITB (181%) i needed to do a Firmwareupdate (New ITB Type F555).
    But it offered me a firmware starting with a whole lot of numbers, but ending with JP_US...
    I wasn't realy having a good day, so I got a bit scared seeing the JP in the name. Not sure if the JP_US meant it was japanese and/or English (US) and NOT wanting to explain why their Copyier 'suddely' was in japanese I decided to pospone the upgrade until i asked you guys...
    So is xxxxxxxx.JP_US a firmware in japanese or did I just make a fool of myself overhere thinking is was ?
    Johan
  • dan7777
    • Dec 2012
    • 680
    Re: a 'quick' firmware naming question
    That was funny! I think you may have been right. This was in my irca2030 folder "SYSTEM_4601-JEFIGS-DCON_6705". I think you can have several versions in the folder. The folder name should be IAC2030 on the usb and then a folder inside it. There are files inside the SYSTEM_4601-JEFIGS-DCON_6705 folder.
    • JPiek
      • Oct 2014
      • 435
      Hi Dan7777,
      Glad I didn't update then, that would have really ruined my day
      But that file was offered in 'service menu'-> 'Updater'
      I really tought that would give me the latest and correct firmware... I had the option to scroll down through a list of ad. languages, but there was no 'English'...
      Johan
      • dan7777
        • Dec 2012
        • 680
        Hi Dan7777,
        It seems like that is only 6 months or so old. You have a box with different languages but I use the drop down list to update (above the different language box.) Maybe you should update USB if you have access to that.
        • JPiek
          • Oct 2014
          • 435
          I found some firmware to d/l :
          SST v47.01.01 - iR-ADV C2030 Series MN-CONT Ver.47.01
          It gave me a file named 20170810iAC2030v470101USJP20170630.0470101.zip containing just a bunch of .NLF files...
          downloading iR-ADV C2030 Series MN-CONT Ver.46.01 gave me a file named 20151026iAC2030v460101USJP20150928.0460101.zip also containing .NLF files.
          Looks the same as the filename offered in the updater in the servicemenu...
          Johan
          • dan7777
            • Dec 2012
            • 680
            I use usb 80% of the time because I think it is faster. If it were me I would go ahead and download what the latest updater was. Or install with sst if that is easier for you.
