My first job tomorrow with an error code E0733-0000, communication error. Just wondering if is the same resolution as posted with previous versions: DCON or MNCON PCB. Any help is welcome. Thanks.
E0733-0000 IRADV8505
Tags: None
Re: E0733-0000 IRADV8505
Hi.you have to check up to that the Reader Unit Cable is connected properly.
(Printer communication error)
1. Check the connection of the Connector with the printer.2. Check the power of the printer (check if the initialization
operation is executed at startup).
3. Replace the DC Controller or the Main Controller PCB.
Unable to communicate with printer at startup.
