canon ir 4570 copied result blank white
  • margono
    • Aug 2017
    • 14
    [Electrical] canon ir 4570 copied result blank white
    please help, I have a problem machine canon ir 4570 copied blank white, nothing result.when I test, it turns out the gear develope does not rotate during the printing process.whether the problem is in clutch motor develope.?Please help
    please help, I have a problem machine canon ir 4570 copied blank puith,when I test, it turns out the gear develope does not rotate during the printing process.whether the problem is in clutch motor develope.Please help
    Re: canon ir 4570 copied result blank white
    does it produce an error code? it could be the clutch or the harness or a board...
    what have you done to it? any repair before the issue appeared?
    more info needed.
    • margono
      • Aug 2017
      • 14
      more info needed.
      no error code, just blank result. I only see when the process of copying, develope does not spin,note: the side door is opened and my drum is out and my door sensor is closed, it will be visible if the develope does not spin
        " I only see when the process of copying, " are you saying that if you print or do the internal prints it produces text?
        have you done a "stop print" to see if image is on the drum?
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5012
          Did you check clutch (FK2-0404) operation (what the arrow indicates on the picture) in service mode?
          PART-CHK>CL>3
          DC controller PCB J313 connector
          • Peter Sim
            • Sep 2008
            • 445
            also can check whether the laser shuttle open cover and also cable broken.
            • margono
              • Aug 2017
              • 14
              image is not on the drum, i try to change the drum until three time but the image is still blank, try change the gear unit drum(like my image above) is only same, i am really confuse, help me please
              • margono
                • Aug 2017
                • 14
                PART-CHK>CL>3
                mr.where can i get how to check all part code in part-chk,
                • zoraldinho
                  • Mar 2008
                  • 5012
                  In service mode of course.
                  • margono
                    • Aug 2017
                    • 14
                    mr, how i check the laser shutter and ccd is good or not?
                      are you a tech or an end user?
                      • margono
                        • Aug 2017
                        • 14
                        i am a new tech mr. this problem is new for me, nothing experience before, help me how to resolve this
