Hi guys
We had a customer call us about a 500iF apparently making a loud noise like it's about to take off lol.
We have it at the shop - seems like it will get to idle and make copies okay, but if you leave it for 2 minutes exactly - and I mean exactly - from idle, the main drive assembly which seems to have the drum, fuser and duplex motor attached will start rotating. It will slowly increase in speed and I don't know how fast it will go but it won't slow down.
It seems like at two minutes that's when the fuser might roll over but doesn't stop.
Any ideas?
I checked the error logs - customer had E202 and E733 codes right before this happened.
I am assuming Main Controller and/or Reader Controller are suspect based on the codes.
We already swapped the DC controller or Engine Controller as Canon call it on this model but no dice.
Fun times.
Any ideas?
Fun times.
