Canon IR2525 Print Outs very light
  • Austin Jacob
    • Jul 2025
    [Misc] Canon IR2525 Print Outs very light
    Recently bought Canon IR2525 and its working fine except the printouts from Computer comes out extremely light (almost in gray).
    Please help me sort out this issue as I am new to canon cadre, Thanks.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon IR2525 Print Outs very light
    Print some reports directly from machine.If you get ok print then check driver settings or install driver again.(ufrII)
    If you get light test prints check settings in printer.(add.function)
      is "toner saver" on in the print driver?
      • petermays
        • Mar 2017
        • 91
        helo..yip toner save is most prob on.go look in your printer settings
          always remember this.. the print driver setting should over rule the control panel settings.
          • Hosta
            Try:
            1 Press (Additional Functions)
            ➞ [Common Settings] ➞ [Printer
            Density].
            Must be 5 or more.
