LAN Printing Problem
  • oxzz
    • Sep 2017
    • 39
    [Misc] LAN Printing Problem
    hello,
    i have IR 3235 and want to print using computer.
    the problem is driver using IP detect on LAN, and i use DHCP setting on my machine and my router.
    every morning when i turn the machine, the IP always change.
    yesterday the machine use IP 192.168.1.12, today the machine use 192.168.1.9
    if the IP is change on machine, i must change the port on Device and Printer setting.
    do you have another way to avoid this?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: LAN Printing Problem
    Turn DHCP to off and use fix ip.
    DHCP vs. Static IP—Which Is Better? | Home Automation Blog
