Cyan as a grid on 9060 Pro
  • V-P
    • Apr 2011
    • 679
    Hi Fellas,
    I have a strange case on a 9060 PRO.
    All drums and developers are almost new (just 5% usage).
    The problem is that cyan comes out as some kind of grid.
    It is not visible on the PG-5 though.
    But when customer prints on thick paper it is visible.
    I have already switched drums between cyan and yellow - and it is the same.
    I have also switched to ON the heater on the back of machine.
    What can it be ?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Cyan as a grid on 9060 Pro
    Hi!
    You probably already tried gradation and calibration ......
    Any differences If you stir cyan developer?
    • V-P
      • Apr 2011
      • 679
      Yes I tried gradation & calibration a couple of times.
      The funny thing is that when I print calibration sheet on thick paper - the cyan degrades very quickly and in a grid filling.
      The other colors look fine.
      PFFFFF
      I am starting to have bad feelings about this series ....
      • zoraldinho
        • Mar 2008
        • 5018
        • V-P
          • Apr 2011
          • 679
          Hi Z,
          I went back to that customer and did all your suggestions.
          Nada...
          Even if transfer roller was in great shape - I still replaced it.
          Developer is almost new - 5 % on counter and also visually it looks perfect.
          Any other ideas except replacing dev unit ?
          Thnx...
          • zoraldinho
            • Mar 2008
            • 5018
            Was the cyan print quality with the old developer the same? Was the procedure for installing a new developer correct? Are the developer values in normality?
            Try with:
            copier>function>install>td-ac for all or only cyan.
            • Herrmann
              • Jan 2006
              • 792
              Had the nearly same Thing Time ago; try to change the Laser Units (I would suggest Yellow against Cyan) and see if the Error goes along with the Cyan Unit
              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
