Hello.
My machine has a fiery on the back of the unit but it doesn't seem to be installed correctly. It's all plugged in and connected to the copier but there doesn't seem to be any options on the control panel to access the settings. When it's connected to the network the machine picks up what I assume is the fiery ip address of 10.x.x.x but I can't find the actually address of the machine and using a network scanner doesn't locate the machine either.
Is there a "factory reset" I can perform on the fiery to reinstall it on the machine if not any suggestions as to why I can't see the fiery.
Chris
Chris
