Canon 3300 part # needed
  • wild140
    • Feb 2017
    • 70
    looking for the part # for the dual cassette option lift assy , Bottom drawer tries to lift and just skips , Or if anyone has one in their graveyard please e-mail me steve@frpremierrcopiers.com
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon 3300 part # needed
    Did you checked what exactly is in the malfunction? Gear,motor....
    • dan7777
      • Dec 2012
      • 680
      There are metal springs that sometimes break and the lift gear breaks a tooth. I used to replace the entire feed assembly to fix some of those as either the top or bottom lift gear is a pain to change.
      • dan7777
        • Dec 2012
        • 680
        cassete lifter failure to rise.pdf
        • kuby
          • Oct 2007
          • 1409
          Either one of the springs or Ratchet gear - FB6-2778. Good luck finding a Pickup assembly. Have repaired these in the past with the ratchet gear.
