Erorr code E263 - 000
  • Blues Guy
    • Aug 2009
    • 216
    Good day guys,I have a unit IRADV 6055 with error code E263 - 000 when you ON the machine. We have replace all the P.C.B interchange from a working condition machine but still the same problem.Any idea what else to check guys ?
  • fm100
    • Sep 2013
    • 14
    Re: Erorr code E263 - 000
    Hi,
    Fixing unit connector at back of machine - (not the one on the fuser) has a short / nipped wire. Replace this connector along with its associated wiring loom.
    • teckat
      • 16083
      Did u check fuses on Main Driver ?
      Did u check your DC voltages at J101 of the Main Driver PCB. _?
      If non _ Replace that Main Driver pcb, & Relay pcb
