IPF8300 parts
  • jumeda33
    • Jul 2015
    • 55
    IPF8300 parts
    Hi,
    Thanks to the help of you guys on the forum it has been determined that I need a main board. Does anyone have or know where to get a main board for an IPF8300? Part number QM3-3153-010.
    thanks,
    david
  • guitar9199
    • Sep 2016
    • 1100
    Re: IPF8300 parts
    Hytec USED to do Wide Format boards, but apparently they must have recently stopped. I searched their catalog and found ZERO boards for wide-format.
    If you're unable to order directly from Canon, I was able to Find a few online. However, if you're not a tech, I strongly recommend you pay the extra to have one install it for you. There's a specific procedure for replacing the Main Controller, and it might even require the firmware to be updated at installation.
    • jumeda33
      • Jul 2015
      • 55
      Re: IPF8300 parts
      Hey Guitar,
      Do you know if the firmware is saved on that board? I know I have the most up to date firmware right now but I am wondering if I change that board will I have to update the firmware or will it still be in the machine?
      Thanks,
      David
      • V-P
        • Apr 2011
        • 679
        Re: IPF8300 parts
        The firmware is saved on the mainboard.
        When you get a new mainboard from Canon - it is to the latest version
        You should replace mainboard and both printheads.
        If you put a new mainboard and old printhead - there is risk that old (burnt printhead) might burn the new main board.
        • teckat
          • 16083
          Re: IPF8300 parts
          • jumeda33
            • Jul 2015
            • 55
            Re: IPF8300 parts
            Hey V-P,
            Thanks for the help. I put two brand new ph's in since the codes said the right ph was bad which I don't think it was and the nozzle check test print wouldn't print the yellow box so I thought changing both would take care of it. After I changed the ph's is when I then did another nozzle check and that's when I saw Photo Cyan not printing and that is how I got here. So with all that being said I hope the two new ph's are still ok. From what teckat posted below it looks like if I do what is listed in the link it will keep all the info that the machine has. I found a new board on Ebay for 769.00 which is the cheapest I can find. If you know anywhere else to look that would be great.
            Thanks,
            David
