copy,scan,print,fax machine-opinion
  • CMB
    KonicaMinolta Tech.
    • Mar 2005
    • 457
    i'm looking for one for my home. i would like to have the scanner to have as high resolution as possible for scanning pictures. a laser unit will be a little out of my price range at this time, so i'm limited to ink or bubble jet.
    any suggestions from your personal experiences?? i don't work on printers or faxes and have no idea what would be a good brand or model for the device i'm seeking.
  • knightfall
    • Jul 2006
    • 633
    There are a lot of scanners out in the market and will do a good job for the home use. All scanner will give you up to 600 dpi resolution and some will give you 1200 dpi using software manipulation. If you use photoshop all scanners have a plugin for photoshop (twain driver). In general all scanners do a good job but you will have to check out the types of scanners out in the market and decide if you want a document feeder or not. I currently use a Canon LiDe scanner I use to scan all my pictures to digital files and use a Canon i850 inkjet printer to print photos out. So good luck and have fun shopping for a scanner and printer.
    Get your facts first, and then you can distort them as much as you please.
    • copi_40
      • Mar 2006
      • 49
      Lexmark X215 ( In fact samsung SCX 4216 ) . I saw that Canon multifunctionals machine from Laser Base MF series (better machine ) are not available in USA !!!????? I belive you do not want a inkjet toy !!!
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        As 4 the scx 4216 mentioned keep in mind that it is disposible like all the other samsung printers...spend a couple more bucks on something else!
        Mystic Crystal Revelations
        • kyoceradude
          The Great Gazoo
          • Aug 2006
          • 442
          Samsung MFP's
          We sell the Samsung and Muratech products. The Samsung toner yield sucks, and the cost for supplies is kind of high. Unless you buy aftermarket supplies.. Muratech is a better bang for the buck. (in my opinion)
          My mission here on Earth is to help all you Dum-Dums!
          • suckis
            • Dec 2006
            • 165
            samsung SCX 4216
            ! RTFM !
            My site: http://www.e-club.gr/
