Paper jam before drum. Ir3045
  • patjanuari
    • 7
    [Jamming] Paper jam before drum. Ir3045
    Pls..my canon ir 3045 always jammed before drum.
    Any suggestion with that.
    Thank you
  • kuby
    • Oct 2007
    • 1408
    Re: Paper jam before drum. Ir3045
    Need more info...From tray 1, 2, 3, 4, Bypass?
    • Exceltech
      • May 2012
      • 14
      The upper cassette right side door probably has the old foam strip to give pressure on the paper path guide that flips down when you open the door.
