Exchange an Firmware
  • first.clis
    • Nov 2017
    • 7
    [Misc] Exchange an Firmware
    i have ir5000/6000,5000n,5000d,6255/65/75,5020(i) firmware
    i need 6055 or 6020 for exchange.
    send me an message if you want to trade .
  • kuby
    • Oct 2007
    • 1406
    Re: Exchange an Firmware
    I am pretty sure that the 5020 works on the 6020.
    • teckat
      • 16083
      iR 5020(i)/6020(i)===========same dog ----Barking-Dog.jpg
      iR6055--u mean Advanced Series
      why do u need firmware ?? if u are a tech > u should have known 5020 & 6020 use same firmware
      • first.clis
        • Nov 2017
        • 7
        Originally posted by teckat
        iR 5020(i)/6020(i)===========same dog ----[ATTACH=CONFIG]38095[/ATTACH]
        i have try using 5020 firmware for 6020i, still no luck .
        yes i have IR ADV 6055 without Direct Print PDF, i need firmware for adding this mannually. (before i have try adding Direct Print PDF on 6275 machine and it's work)
        im not a tech but just user, and i have 3 copy center .
        i'll try it again .
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5014
          On Advance series you can update the firmware of the machine to the most recent version using the "Register/Update Software" function from the Remote UI.
          Updating Firmware
          Logging In to the Machine as an Administrator
          • first.clis
            • Nov 2017
            • 7
            i'm still need 6055/55/75 firmware for exchange, just send me a message .
