canon ir3180
  • Serviceusam
    • Nov 2017
    • 11
    canon ir3180
    the machine displays 020-081. don't know where to start from. can't seem to find anything on it, nor a service manual.
    any help would be much appreciated. thank you!
  • acfife
    • May 2012
    • 63
    Re: canon ir3180
    It is usually the patch sensor is dirty, very common issue on this range, if you remove the black toner cartridge, you can get access to clean it in the machine, reach in open shutter and wipe the sensor.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: canon ir3180
      I agree.Also clean laser glass.
      • Canuck
        Tech Specialist
        • 1713
        Re: canon ir3180
        Pull out the drum and clean the patch reader....upper left I believe. Its been a long time since I've seen one...
