canon ir2520 jam 0107 A4 and first part of paper in fuser
  • newdente.gianluca
    • Feb 2016
    • 60
    [Jamming] canon ir2520 jam 0107 A4 and first part of paper in fuser
    hi, i have the canon ir 2520 and always jamming, i have changed fixing film and pressure roller, please help.
  • newdente.gianluca
    • Feb 2016
    • 60
    Re: canon ir2520 jam 0107 A4 and first part of paper in fuser
    with an old fixing film the machine works fine, someone has the oem code of the fixing film?
    • rudysemira
      • Oct 2016
      • 108
      how many papers did you print?
      1 copy is good
      for multiple copies did you encounter paper jam? or what?
      give more details.....
      • rudysemira
        • Oct 2016
        • 108
        did you place correctly the fixing film....check the mark....
        • aeshen2
          • Sep 2016
          • 8
          did you change the bushigs of presure roller also, if not replace ,if the problem not solve so you have to consider about the film you replaced ,som of fixing film not working properly and the silicon past we used for that is some times not enought to rotate the film correctly
          • charm5496
            • 2387
            there is a duplex clutch that can cause this jam code on the 2525 series machines
            • newdente.gianluca
              • Feb 2016
              • 60
              first copy: ok, second ko,all wase installed correctly, i resolved the problem changing grease past. thanks.
