Canon department id printing qouta every month
  • eng_usama
    • 115
    Hello guys hope you can help me
    We use Canon copier and we print or copy with department id and password
    With limited number of copy or print for every id
    I wanna ask about two options
    Is there way to adjust copier to clear counters for every I'd
    In spasific date without do it manually ?
    2nd is there anyway to store for 3 or 4 months how much copy or printing paper
    Every id done ?
    Wait for replay many thanks
  • mosey1100
    • Mar 2009
    • 143
    Re: Canon department id printing qouta every month
    Every id done ?
    The only way to clear counts is manually and if you want to track how much every ID has done in a specific time frame you can print the totals first before you clear them and file them so you have a record.
    • teckat
      • 16083
      Every id done ?
      imageWARE Accounting Manager for MEAP-----------
      Question :
      How do you display total results in Accounting Manager for MEAP's web interface?
      Can this also be performed in the Data Collecting Application?
      Answer :
      You can display a total of the jobs performed on the MEAP device in the Accounting Manager for MEAP's servlet (web interface). The total results can be displayed according to job type (copy, print, etc) and units (department ID or user name). You can also export the total results.
      The following two types of job total results can be displayed:
      1. Total Results up to Now - The total results from the last time you reset the total results to the present time is displayed.
      2. Scheduled Total Results - The results of scheduled totals are displayed. The Scheduled Total function enables you to calculate the total jobs from the last time you reset the total results to the specified day.
      If there are no results for a scheduled total, the date for [Scheduled Total Results] is shown as hyphens (-).
      To Display (Calculate) the Total Results:
      1. Select your desired options (Time Frame, Job Type, Color Mode, and Units).
      2. Click the [Display Total Results] button.
      3. Click [Total Details] to re-select your desired options. Click [Export] to export the total results to a CSV file.
      Important:
      - If you select 'User Name' for the units, print jobs from the print driver are calculated according to Windows login name. Also, if you are using SDL or SSO, copy jobs are calculated according to SDL or SSO user name. If you select 'Department ID' for the units, jobs are calculated according to department ID.
      - The values in the total results and the counter values of the MEAP device may not correspond. See Related Article 60681 and Related Article 60660 for limitations in tracking jobs.
      - Received fax jobs, report jobs (ex. Activity reports), and output not managed with a department ID or user name is always calculated as 'Other'.
      - When calculating scan jobs, pages are counted regardless of whether the sending process or storing process was successful or not.
      Resetting the Total Results:
      You can reset the total results by clicking the [Reset Total Results] button. The date you reset the total results becomes the starting date for the next time you calculate the total results.
      Setting a Scheduled Total:
      You can calculate the total results from the last time you reset the total results to the specified date. The scheduled total results can be displayed and exported (as described above) at any time until the next total is calculated. You can also use the [Reset Total Results] option to automatically reset the total results and therefore regularly calculate totals for a specified period.
      1. Click the [Scheduled Total Settings] button to set this function.
      2. Check on the [Schedule Total] option.
      3. Set the interval to automatically calculate the totals (daily, weekly, or monthly), the day/date and time to perform the calculation, and whether or not to automatically reset the total results at this time as well.
      4. Click OK.
      - If the MEAP device is powered off at the scheduled time, the scheduled total will be performed when the device is powered back on.
      - If you change the [Date/Time Settings] on the MEAP device after setting a scheduled total, you must restart the MEAP device.
      - If the scheduled date is set for a value (ex. 29, 30, 31) that does not exist on a particular month (ex. February), the scheduled total will be performed on the last day of that month.
      Clearing the Scheduled Total Results:
      You can clear the scheduled total results by clicking the [Clear Scheduled Total Results] button. Total results which have been cleared cannot be displayed or exported.
      Data Collecting Application:
      You can perform most of these same functions from the Data Collecting Application. You cannot directly display the total results in the Data Collecting Application, but you can collect the total results, storing them as CSV files. 14 CSV files are created for each selected MEAP device when the [Collecting Total Results] option is used.
      The advantage of using the Data Collecting Application is that you can perform these functions on multiple MEAP devices at the same time.
      • teckat
        • 16083
        What is imageWARE Accounting Manager for MEAP?
        'Accounting Manager for MEAP' is an application compatible with MEAP which enables you to calculate the total print and copy jobs output and number of originals scanned in MEAP devices. Output totals and scan totals can be calculated according to department or user, enabling you to check the usage of each department or user. Therefore, you can manage cost distribution of departments and lower output costs.
        As the job logs (such as copy, fax, and scan logs) used for calculating totals are stored on the MEAP device (imageRUNNER machine which supports the MEAP function), a dedicated server is not necessary. The job total results can be viewed by simply accessing the MEAP device with the designated Web browser. Total results can also be exported to a computer in CSV format.
        * Note - 'imageWARE Accounting Manager for MEAP' is a stand-alone MEAP application. It is a separate product that runs on its own. A server running 'imageWARE Accounting Manager' is not required. 'imageWARE Accounting Manager for MEAP' and 'imageWARE Accounting Manager' are two separate products.
        The various functions of Accounting Manager for MEAP are as follows:
        1. Calculating job totals according to the job type:
        You can calculate job totals according to the job type, such as copy jobs and print jobs. The totals of the following job types can be calculated with 'Accounting Manager for MEAP':
        - All output jobs (all output/copy/print/mailbox/received)
        - Sent faxes
        - Scan jobs
        - Totals of scan jobs cannot be calculated with the imageRUNNER 2220i / 2220N / 3320i / 3320N / 5020 / 6020.
        - Report print jobs, such as activity reports, cannot be calculated separately.
        2. Exporting total results:
        You can save total results calculated with 'Accounting Manager for MEAP' to your computer in CSV format.
        3. Scheduling total calculation:
        You can schedule a day and time to periodically perform the total calculations. For example, you can set it to calculate the job totals from the first day to the last day of every month anytime during the next month.
        4. Exporting job logs:
        You can save all of the logs of jobs performed on the MEAP device to your computer in CSV format. You can also use the Automatic Export function to periodically export the job logs.
        5. Data Collecting Application:
        When calculating job totals with multiple MEAP devices using 'Accounting Manager for MEAP', you can use the Data Collecting Application to save the total results of each MEAP device in CSV format.* Note - Before starting 'Accounting Manager for MEAP', set one of the following login services (services provided for managing the user information on the MEAP devices):
        - Department ID Management
        - SDL (Simple Device Login)
        - SSO (Single Sign-On)
        6. Backing up and restoring data:
        You can back up the user information, displayed totals information, and job log files.
        • eng_usama
          • 115
          thank you all guys for answer me
