IRC adv 5255i E000029-0003
  • JPiek
    • Oct 2014
    • 435
    Hi Guys,
    Tomorrow to a Copier with error E000029-0003... Could not find much on CTN. Nor in the manual. just to check connections or replace sensor ?
    Could it just be spoiled toner on the sensor ?
    I assume i would have to remove the ITB to get to it, judging by the manual ?
    Any hints or suggestions are welcome...
    Johan
  • charm5496
    • 2387
    Re: IRC adv 5255i E000029-0003
    it could be that the shutter is bound up and not opening up for the windows to read the patches correctly. Also check the arm that connects the solenoid to the shutter.
    • guitar9199
      • Sep 2016
      • 1100
      • JPiek
        • Oct 2014
        • 435
        Thanks Huys,
        that helped a lot !
        Opened up the copier, removed the ITB and saw the hook (gray thingy) that is supposed to open the shutter is broken. (see image)shutter.jpg
        I tried prieing it back But it pulled out again... But is was enough to get the copyer printing again... I manually opened the shutter and it kept printing.
        I'm not sure for howlong though so i guess it has te be replaced. whats the part to buy and how do i get it out ?
        Johan
        • JPiek
          • Oct 2014
          • 435
          Found the partno. i think : FM3-8902-010, but when I google it it comes up as a 5030 model... I ot it form the 52xx Partsmanual though...
          The servicemanual has no info on how to replace it ?
          Thanks again guys !
          Johan
          • guitar9199
            • Sep 2016
            • 1100
            Thanks again guys !
            Your replacement procedure is on 4-108, under "Removing the Patch Sensor".
            • JPiek
              • Oct 2014
              • 435
              I'm sorry, I only see how the remove the shutter and patch sensor...
              Can't see them removing the shutter drive assy...
              Johan
              • JPiek
                • Oct 2014
                • 435
                Shutter drive assy has been replaced. Works as a charm now. Thanks for the help guys !
                Johan
