Canon IR ADV C9060 Pro printing not straight.
  • Cmp4you
    • Oct 2016
    • 37
    [Misc] Canon IR ADV C9060 Pro printing not straight.
    Hello guys,
    I have always thought our cutting machine had to be recalibrated, because every cutting wasn't right. On one side it was about 1.5mm off, everytime.
    Today I measured the distance between the document content and the paper edge and it turned out that there is a difference of 1.5mm on the long side. So it seems the printing is off. Is there a way for me to fix this problem?
    Thank you for your help!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon IR ADV C9060 Pro printing not straight.
    Can you post a sample?
    • roho
      • Mar 2009
      • 844
      Is this from all trays consistently, or are the results different from each tray? Are the images crooked in any way, or is this just a question of registration? There are quite a few adjustments available depending on the type of issues and a thorough procedure to bring these to spec.
