IR C5051
  • Staggan
    • Jan 2017
    • 54
    IR C5051
    Hello
    After some advice.
    Have an IR C5051 which is showing the green power light but will not come to ready...
    I turn the machine off via the side button... turn it back on, green light but nothing else.. Turn it off and turn it off at the mains, leave it half hour then turn it all back on and it comes to ready.. MOST of the time.
    If I put it into sleep mode it wakes up without issue....
    Any thoughts? Currently thinking power supply... but not 100% convinced.
    I've already disconnected and reconnected every connector I can on the power boards... and the screen / keypad...
  • guitar9199
    • Sep 2016
    • 1100
    Re: IR C5051
    First thing I'd try is when you get it to come up, go into the settings and switch sleep from "Low Power" to "High Power" mode in the power settings. I've seen that do exactly what you're describing.
    Settings/Registration;Timer/Energy Settings, Sleep Mode
