ira6065 E302
  • markndreu
    • Mar 2014
    • 34
    ira6065 E302
    Hi
    Someone Can Help me because i have very very big problem with canon Advance6065 It give me error E000302-0001 ?
    Do you know any solution please????
  • mosey1100
    • Mar 2009
    • 143
    Re: ira6065 E302
    Originally posted by markndreu
    Hi
    You could try this.
    • rudysemira
      • Oct 2016
      • 108
      Re: ira6065 E302
      Hi
      E302 0001 -04 Title Error in paper front shading
      Detection
      description
      Error in shading RAM access, or the shading value is either
      below or higher than the reference level.
      Remedy 1. Connector disconnection/open circuit of the Scanner Unit
      (Reader).
      2. Connector disconnection/open circuit of the Reader
      Controller PCB (PCB1).
      3. Failure of the Scanner Unit (Reader).
      4. Failure of the Reader Controller PCB (PCB1).
      E302 0101 -04 Title Error in paper back shading
      Detection
      description
      (DADF).
      3. Operation error of the Glass Shift Motor (M9).
      4. Failure of the Scanner Unit (DADF).
      5. Failure of the Reader Controller PCB (PCB1)
      Try this method to solve your problem....
