error e000025-0310 canon c7055
  • dan7777
    replied
    Re: error e000025-0310 canon c7055
    Originally posted by chrisio
    Ha Ha - I had assumed that you were in Bristol UK - yes that would be a very expensive call out! Now my local tech has seen it they are going to work with me to come up with a sensible price to fix it - The last question I have is - if I replace the colour hopper all together do I need to replace the gear as well or is it part of the hopper? or is the gear separate to the hopper?
    Cheers
    Chris
    Last time I did it the broken gear was in front of the color hopper (one hopper for each color). So I could have fixed it with one gear. I took the gear off the old hopper. My machines are under contract so the cheap way was with one gear but I don't want to do this again is why I ordered hopper. I forgot about the gear in front of the hopper. Do not know why I had to replace two good black developers after this work. My guess is the toner gets compacted during the moving of them and why some techs said they vacuumed out all the black toner from the hopper first. I treated the last one like a new born baby and still had to replace it.
  • chrisio
    replied
    Originally posted by dan7777
    I think you would be ok with 2. It was suggested I replace the gears on the other color hoppers but I do not always do it and so far I do not have the same issue on each machine I do. When I had extra gears I did. Next time I am going to order color hopper and gear for front side, color hopper has same gear on it. The post about fishing the gear out was legit but you have to know where it is. Once you get to the color hoppers it is not that much more to take it out. But in doing this I have had to replace two black hoppers. There is a way you have to line up the gear when you put the black hopper and both times mine coded out that gear was in the correct place. Penrith is on the other side of the ocean from the USA I think. I would do it for free for a friend, my company charges $125 an hour plus $60 for each 1/2 hour of travel time from office. That and a plane ticket may add up to a little.
    Cheers
    Chris
  • dan7777
    replied
    Sorry to keep digging over this - If I got 2 new gears and replaced them both I should be up and running - no need to replace the colour hopper? if that's the case it may be worth while finding someone who is able to perform this level of surgery!
    since I am in this deep to the machine would it be worth replacing the other gears on the other colours?
    BTW I notice your in Bristol! what is your mileage rate to come to Penrith for the day!!
    Cheers
    Chris
  • dan7777
    replied
    Originally posted by Canuck
    Not as much as taking out the color hopper. Black hopper has to come out, drums ,drum drives, devs, itb, hvt,dev drive assembly and others. I can reach inside the hopper assembly after loosening its screws and fish out the gear. Not a pleasant service call...
    That was funny! "not a pleasant service call" was a very nice way to say it! You have been there, done that. I still have several of those machines as they seemed to resell them for a while, After you do it 3 or 4 times it is not that bad, am I correct saying that? Just long and painful. I would drop something trying to fish out the gear but you could do it that way. I dropped a simple to put on clip on a 7065 fuser today I had to take the belt units back out to get to it.
  • chrisio
    replied
    You could get by with one (one way) gear but it could be two. Last time I thought I would replace the color hopper and it still ended up being the gear in front of it was cracked. $5 part but a couple hours of labor. I got help the first time but have done many since then. [ATTACH=CONFIG]38339[/ATTACH]
    Cheers
    Chris
  • JPiek
    replied
    This pic is a 5000 series....nothing to do with 7055
    On the top of the video :
  • Canuck
    replied
  • chrisio
    replied
    I have replaced the cracked oneway gear many times on the color hopper. I can do it without removing the hopper...
    Does it require as much strip down?
  • Canuck
    replied
  • Canuck
    replied
    Originally posted by JPiek
    Is this what you mean ?
    Or maybe you just can't open the door because there is no message to replace the toner ?
    Then change the setting in COPIER > OPTION > DISPLY-SW
    and in user mode : Adjustment/Maintenance > Maintenance > Replace Specified Toner
  • dan7777
    replied
    Thank very much.
    Is it the actual colour hopper that needs replacing or just the one way gear or both. To be honest though I may just end up writing the machine off as the cost to pay a tech to do this job is going to cost a few hundred at least plus the cost of the parts.
    Decisions Decisions!
    Cheers
    Chris
    You could get by with one (one way) gear but it could be two. Last time I thought I would replace the color hopper and it still ended up being the gear in front of it was cracked. $5 part but a couple hours of labor. I got help the first time but have done many since then. gear2.jpg
  • chrisio
    replied
    Thank very much.
    Cheers
    Chris
  • dan7777
    replied
    Hi.
    The toner is actually stuck. I have opened the back panel and attempted to remove with the manual winder and no go - its just spinning - I have unlocked another colour no problem but the cyan is just clicking around and no unlock.
    Chris
    There is a broken one way gear on the color hopper of the toner you can not get out. Last time I ordered the hopper instead of the one way gear and there was also a broken one way gear on the front that I took off the old color hopper. We have had several. Getting to the hopper is a real pain, use the service manual. Twice I have done this and had to replace the black hopper after re assembly. I was real careful with the black hopper last time but still got error code for black hopper after replacing. Some tech reported they vacuum the black hopper out first. It takes me a couple of hours, I go slow to get everything right. You have a big job to do!
    I will post a picture of the back of the machine after the color hoppers are out. The gear is FU6-0584-000.
  • chrisio
    replied
    Hi.
    Chris
  • JPiek
    replied
