paper size setting FLS
  • KHAN
    • Aug 2006
    • 261
    [Misc] paper size setting FLS
    Hello friends I want to change my 2nd draw paper size setting to FLS size how can I change.thanks
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5019
    Re: paper size setting FLS
    Model?
    • KHAN
      • Aug 2006
      • 261
      Re: paper size setting FLS in Canon ir 2535
      Sorry I forget the make and model name.
      • zoraldinho
        • Mar 2008
        • 5019
        1. Press [Paper Settings] repeatedly to select <CASSETTE 1> or <CASSETTE 2>, then press [OK].
        <CASSETTE 2> is displayed only if the optional paper cassette is attached.
        2. Press or to select the paper size, then press [OK].
        You can select from the following paper sizes:
        <A4>, <B5>, <A5>, <EXECUTIV>, <OFICIO>, <B-OFI>, <M-OFI>, <G-LTR>, <G-LGL>, <FOOLSCAP>, <A-FLS>, <LTR>, or <LGL>.
        3. Press or to select the paper type, then press [OK].
        You can select from the following paper types:
        <PLAIN PAPER>, <PLAIN PAPER L>*, <RECYCLED>, <COLOR>, or <HEAVY PAPER 1>.
        • KHAN
          • Aug 2006
          • 261
          Thanks for your reply. But I didn't find paper setting any where, press additional function ,then commun setting there I found only paper type , nothing for the size . Only I can select the size in stuck bypass there I can put the size in X. ??? and in Y .?? but I need it for cassette or drawer . Thanks
