Dear friends:
I have a problem with a Canon iR ADV500i. As you can see when I print the counter report it is not complete Bad.pdf. The normal printing is like this Bad.pdfGood.pdf.
I have with LTRr and A4 size. It happends when I print or copy from the casette and the manual tray. But when I customize the size is OK.
What I have done:
- Clean the pre-registration and registration sensors.
- Check and clean all the sensor located in the recollection unit.
- Part-CHK is all OK.
Do you have any idea about this problem?
Thanks.
What I have done:
Thanks.
