Wrinkle tailing page
+ More Options
Posts
  • khattab.al.masry
    • 212
    [Misc] Wrinkle tailing page
    We face problem with our imagepress c1+
    That wrinkled tail page
    We enter the correct madia
    And that done with coated A3
    But with coated A4 works fine no problem
    We replaced pad pressure and oil roller and fixing belt
    Is there something we missed?
    Thanks in advance
    Sent from my SM-J700H using Tapatalk
  • guitar9199
    • Sep 2016
    • 1100
    Re: Wrinkle tailing page
    Are you hearing any thumping noise from your fuser? You MIGHT have a worn fixing drive gear... there was an issue a while back where the gears were failing at around 50-70K pages. Also, be sure to check and see that you did not accidentally throw away the plastic spacer stuck to the bottom of the pressure plate if you have already replaced the pad.
    • khattab.al.masry
      • 212
      Thanks every body here
      The issue solved by replacing pad pressure and pad cover as that mentioned in service manual
